Configure Admin proxy settings
PDF of this doc site
Install and maintain appliance hardware
Install and upgrade software
Perform system administration
Monitor and maintain StorageGRID
Recover and maintain
Grid node recovery procedures
Creating your file...
If you send AutoSupport messages using HTTP or HTTPS (see Configure AutoSupport), you can configure a non-transparent proxy server between Admin Nodes and technical support (AutoSupport).
You have specific access permissions.
You are signed in to the Grid Manager using a supported web browser.
You can configure the settings for a single Admin proxy.
Select CONFIGURATION > Security > Proxy settings.
The Admin Proxy Settings page appears. By default, Storage is selected in the sidebar menu.
From the sidebar menu, select Admin.
Select the Enable Admin Proxy check box.
Enter the hostname or IP address of the proxy server.
Enter the port used to connect to the proxy server.
Optionally, enter the proxy username.
Leave this field blank if your proxy server does not require a username.
Optionally, enter the proxy password.
Leave this field blank if your proxy server does not require a password.
Select Save.
After the Admin proxy is saved, the proxy server between Admin Nodes and technical support is configured.
Proxy changes can take up to 10 minutes to take effect. -
If you need to disable the proxy, deselect the Enable Admin Proxy check box, and select Save.
