Pausing and resuming the decommission process for Storage Nodes
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
If necessary, you can pause the decommission procedure for a Storage Node during certain stages. You must pause decommissioning on a Storage Node before you can start a second maintenance procedure. After the other procedure is finished, you can resume decommissioning.
You must be signed in to the Grid Manager using a supported browser.
You must have the Maintenance or Root Access permission.
Select Maintenance > Maintenance Tasks > Decommission.
The Decommission page appears.
Click Decommission Nodes.
The Decommission Nodes page appears. When the decommission procedure reaches either of the following stages, the Pause button is enabled.
Evaluating ILM
Decommissioning Erasure Coded data
Click Pause to suspend the procedure.
The current stage is paused, and the Resume button is enabled.
After the other maintenance procedure is finished, click Resume to proceed with the decommission.
