Changing the consistency level
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
If you are using an S3 tenant, you can use the Tenant Manager or the Tenant Management API to change the consistency control for operations performed on the objects in S3 buckets.
You must be signed in to the Tenant Manager using a supported browser.
You must belong to a user group that has the Manage All Buckets or the Root Access permission. These permissions override the permissions settings in group or bucket policies.
Consistency level makes a trade-off between the availability of the objects and the consistency of those objects across different Storage Nodes and sites. In general, you should use the Read-after-new-write consistency level for your buckets. If the Read-after-new-write consistency level does not meet the client application's requirements, you can change the consistency level by setting the bucket consistency level or by using the Consistency-Control
header. The Consistency-Control
header overrides the bucket consistency level.
When you change a bucket's consistency level, only those objects that are ingested after the change are guaranteed to meet the revised level. |
Select STORAGE (S3) > Buckets.
Select the bucket name from the list.
The bucket details page appears.
Select Bucket options > Consistency level.
Select a consistency level for operations performed on the objects in this bucket.
Consistency level Description All
All nodes receive the data immediately, or the request will fail.
Strong-global
Guarantees read-after-write consistency for all client requests across all sites.
Strong-site
Guarantees read-after-write consistency for all client requests within a site.
Read-after-new-write (Default)
Provides read-after-write consistency for new objects and eventual consistency for object updates. Offers high availability, and data protection guarantees. Matches Amazon S3 consistency guarantees.
Note: If your application attempts HEAD operations on keys that do not exist, set the Consistency Level to Available, unless you require Amazon S3 consistency guarantees. Otherwise, a high number of 500 Internal Server errors can result if one or more Storage Nodes are unavailable.
Available (eventual consistency for HEAD operations)
Behaves the same as the Read-after-new-write consistency level, but only provides eventual consistency for HEAD operations. Offers higher availability for HEAD operations than Read-after-new-write if Storage Nodes are unavailable. Differs from Amazon S3 consistency guarantees for HEAD operations only.
Select Save changes.
