Resetting the preferred sender on the recovered non-primary Admin Node
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
Your file is ready
If the non-primary Admin Node you are recovering is currently set as the preferred sender of alert notifications, alarm notifications, and AutoSupport messages, you must reconfigure this setting in the StorageGRID system.
What you'll need
You must be signed in to the Grid Manager using a supported browser.
You must have specific access permissions.
The recovered Admin Node must be installed and running.
Steps
Select Configuration > System Settings > Display Options.
Select the recovered Admin Node from the Preferred Sender drop-down list.
Click Apply Changes.
Related information
