      Reset preferred sender on recovered non-primary Admin Node
If the non-primary Admin Node you are recovering is currently set as the preferred sender of alert notifications, alarm notifications, and AutoSupport messages, you must reconfigure this setting in the StorageGRID system.
What you'll need
You must be signed in to the Grid Manager using a supported web browser.
You must have specific access permissions.
The recovered Admin Node must be installed and running.
Steps
Select CONFIGURATION > System > Display options.
Select the recovered Admin Node from the Preferred Sender drop-down list.
Click Apply Changes.
Related information
 PDFs
PDFs
