Confirm object data locations
PDF of this doc site
Install and maintain appliance hardware
SG100 and SG1000 services appliances
Install and upgrade software
Perform system administration
Monitor and maintain StorageGRID
Recover and maintain
Grid node recovery procedures
Creating your file...
Depending on the problem, you might want to confirm where object data is being stored. For example, you might want to verify that the ILM policy is performing as expected and object data is being stored where intended.
You must have an object identifier, which can be one of:
UUID: The object's Universally Unique Identifier. Enter the UUID in all uppercase.
CBID: The object's unique identifier within StorageGRID . You can obtain an object's CBID from the audit log. Enter the CBID in all uppercase.
S3 bucket and object key: When an object is ingested through the S3 interface, the client application uses a bucket and object key combination to store and identify the object.
Swift container and object name: When an object is ingested through the Swift interface, the client application uses a container and object name combination to store and identify the object.
Select ILM > Object metadata lookup.
Type the object's identifier in the Identifier field.
You can enter a UUID, CBID, S3 bucket/object-key, or Swift container/object-name.
If you want to look up a specific version of the object, enter the version ID (optional).
Select Look Up.
The object metadata lookup results appear. This page lists the following types of information:
System metadata, including the object ID (UUID), the version ID (optional), the object name, the name of the container, the tenant account name or ID, the logical size of the object, the date and time the object was first created, and the date and time the object was last modified.
Any custom user metadata key-value pairs associated with the object.
For S3 objects, any object tag key-value pairs associated with the object.
For replicated object copies, the current storage location of each copy.
For erasure-coded object copies, the current storage location of each fragment.
For object copies in a Cloud Storage Pool, the location of the object, including the name of the external bucket and the object's unique identifier.
For segmented objects and multipart objects, a list of object segments including segment identifiers and data sizes. For objects with more than 100 segments, only the first 100 segments are shown.
All object metadata in the unprocessed, internal storage format. This raw metadata includes internal system metadata that is not guaranteed to persist from release to release.
The following example shows the object metadata lookup results for an S3 test object that is stored as two replicated copies.
