Object storage audit messages
You should be familiar with audit messages belonging to the object storage audit category. These are events related to the storage and management of objects within the StorageGRID system. These include object storage and retrievals, grid-node to grid-node transfers, and verifications.
Code Description See
APCT
Archive Purge from Cloud-Tier: Archived object data is deleted from an external archival storage system, which connects to the StorageGRID through the S3 API.
ARCB
Archive Object Retrieve Begin: The ARC service begins the retrieval of object data from the external archival storage system.
ARCE
Archive Object Retrieve End: Object data has been retrieved from an external archival storage system, and the ARC service reports the status of the retrieval operation.
ARCT
Archive Retrieve from Cloud-Tier: Archived object data is retrieved from an external archival storage system, which connects to the StorageGRID through the S3 API.
AREM
Archive Object Remove: A content block was successfully or unsuccessfully deleted from the external archival storage system.
ASCE
Archive Object Store End: A content block has been written to the external archival storage system, and the ARC service reports the status of the write operation.
ASCT
Archive Store Cloud-Tier: Object data is stored to an external archival storage system, which connects to the StorageGRID through the S3 API.
ATCE
Archive Object Store Begin: Writing a content block to an external archival storage has started.
AVCC
Archive Validate Cloud-Tier Configuration: The account and bucket settings provided were successfully or unsuccessfully validated.
CBSE
Object Send End: The source entity completed a grid-node to grid-node data transfer operation.
CBRE
Object Receive End: The destination entity completed a grid-node to grid-node data transfer operation.
SCMT
Object Store Commit: A content block was completely stored and verified, and can now be requested.
SREM
Object Store Remove: A content block was deleted from a grid node, and can no longer be requested directly.
