Object storage audit messages
The audit messages belonging to the object storage audit category are used for events related to the storage and management of objects within the StorageGRID system. These include object storage and retrievals, grid-node to grid-node transfers, and verifications.
| Code | Description | See |
APCT  |
Archive Purge from Cloud-Tier: Archived object data is deleted from an external archival storage system, which connects to the StorageGRID through the S3 API.  |
ARCB  |
Archive Object Retrieve Begin: The ARC service begins the retrieval of object data from the external archival storage system.  |
ARCE  |
Archive Object Retrieve End: Object data has been retrieved from an external archival storage system, and the ARC service reports the status of the retrieval operation.  |
ARCT  |
Archive Retrieve from Cloud-Tier: Archived object data is retrieved from an external archival storage system, which connects to the StorageGRID through the S3 API.  |
AREM  |
Archive Object Remove: A content block was successfully or unsuccessfully deleted from the external archival storage system.  |
ASCE  |
Archive Object Store End: A content block has been written to the external archival storage system, and the ARC service reports the status of the write operation.  |
ASCT  |
Archive Store Cloud-Tier: Object data is stored to an external archival storage system, which connects to the StorageGRID through the S3 API.  |
ATCE  |
Archive Object Store Begin: Writing a content block to an external archival storage has started.  |
AVCC  |
Archive Validate Cloud-Tier Configuration: The account and bucket settings provided were successfully or unsuccessfully validated.  |
BROR  |
Bucket Read Only Request: A bucket entered or exited read-only mode.  |
CBSE  |
Object Send End: The source entity completed a grid-node to grid-node data transfer operation.  |
CBRE  |
Object Receive End: The destination entity completed a grid-node to grid-node data transfer operation.  |
CGRR  |
Cross-Grid Replication Request: StorageGRID attempted a cross-grid replication operation to replicate objects between buckets in a grid federation connection.  |
EBDL  |
Empty Bucket Delete: The ILM scanner deleted an object in a bucket that is deleting all objects (performing an empty bucket operation).  |
EBKR  |
Empty Bucket Request: A user sent a request to turn empty bucket on or off (that is, to delete bucket objects or to stop deleting objects).  |
SCMT  |
Object Store Commit: A content block was completely stored and verified, and can now be requested.  |
SREM  |
Object Store Remove: A content block was deleted from a grid node, and can no longer be requested directly.  |
