EBDL: Empty Bucket Delete
The ILM scanner deleted an object in a bucket that is deleting all objects (performing an empty bucket operation).
Code Field Description
CSIZ
Object Size
The size of the object in bytes.
PATH
S3 Bucket/Key
The S3 bucket name and S3 key name.
SEGC
Container UUID
UUID of the container for the segmented object. This value is available only if the object is segmented.
UUID
Universally Unique Identifier
The identifier of the object within the StorageGRID system.
RSLT
Result of the delete operation
The result of event, process, or transaction. If is not relevant for a message, NONE is used rather than SUCS so that the message is not accidentally filtered.
