Changes to the Grid Management API
StorageGRID 11.8 uses version 4 of the Grid Management API. Version 4 deprecates version 3; however, versions 1, 2, and 3 are still supported.
You can continue to use deprecated versions of the management API with StorageGRID 11.8; however, support for these versions of the API will be removed in a future release of StorageGRID. After upgrading to StorageGRID 11.8, the deprecated APIs can be deactivated using the PUT /grid/config/management API.
To learn more, go to Use the Grid Management API.
Changes for ilm-policies API v4
Effective starting with StorageGRID 11.8, version 4 of the ilm-policies API contains the following differences from the version 3:
Historical policies are no longer returned. A new, separate API for getting historical policy and tag data has been added at
/grid/ilm-history. -
Properties removed:
proposed,historical,historicalRules,activationTime. -
Properties added:
active(boolean),activatedBy(array of tag UUIDs that the policy is assigned to). -
The optional type query parameter for
GET ilm-policiesnow takes the valuesinactiveandactive.The previous values wereproposed,active, andhistorical.
New endpoints for drive management
You can use the /grid/drive-details/{nodeId} API endpoints to perform operations on the drives in specific models of appliance Storage Nodes.
