Removed or deprecated features and capabilities
Some features and capabilities were removed or deprecated in this release. Review these items to understand whether you need to update client applications or modify your configuration before you upgrade.
- Deprecated
The feature should not be used in new production environments. Existing production environments can continue using the feature.
- End of Life
Last shipped version that contains the feature. No future versions will support the feature.
- Removed
First version that does not contain the feature.
StorageGRID 11.8 end of feature support
Deprecated features will be removed in N+2 major versions. For example, if a feature is deprecated in version N (for example, 6.3), the last version where the feature will exist is N+1 (for example, 6.4). Version N+2 (for example, 6.5) is the first release when the feature doesn't exist in the product.
See the Software Version Support page for additional information.
In certain situations, NetApp might end support for particular features sooner than indicated. |
| Feature | Deprecated | End of Life | Removed |
Archive Node support |
11.7 |
11.8 |
11.9 |
Audit export through CIFS/Samba |
11.1 |
11.6 |
11.7 |
CLB service |
11.4 |
11.6 |
11.7 |
Docker container runtime |
11.8 |
11.9 |
12.0 |
NFS audit export |
11.8 |
11.9 |
12.0 |
Swift API support |
11.7 |
11.9 |
12.0 |
