Removed or deprecated features and capabilities
Some features and capabilities were removed or deprecated in this release. Review these items to understand whether you need to update client applications or modify your configuration before you upgrade.
Deprecated
The feature should not be used in new production environments. Existing production environments can continue using the feature.
End of Life
Last shipped version that supports the feature. In some cases, documentation for the feature might be removed at this stage.
Removed
First version that does not support the feature.
StorageGRID end of feature support
Deprecated features will be removed in N+2 major versions. For example, if a feature is deprecated in version N (for example, 6.3), the last version where the feature will exist is N+1 (for example, 6.4). Version N+2 (for example, 6.5) is the first release when the feature doesn't exist in the product.
See the Software Version Support page for additional information.
Note In certain situations, NetApp might end support for particular features sooner than indicated.
Feature Deprecated End of Life Removed Links to earlier documentation
Legacy Alarms (not Alerts)
11.7
11.8
11.9
Archive Node support
11.7
11.8
11.9
Note: Before starting your upgrade, you must:
  1. Decommission all Archive Nodes. See Grid node decommissioning (StorageGRID 11.8 doc site).
  2. Remove all Archive Node references from storage pools and ILM policies. See NetApp Knowledge Base: StorageGRID 11.9 software upgrade resolution guide.
Audit export through CIFS/Samba
11.1
11.6
11.7
CLB service
11.4
11.6
11.7
Docker container engine
11.8
11.9
TBD
Support for Docker as the container engine for software-only deployments is deprecated. Docker will be replaced with another container engine in a future release. Refer to the list of Docker versions currently supported.
NFS audit export
11.8
11.9
12.0
Swift API support
11.7
11.9
12.0
RHEL 8.8
11.9
11.9
12.0
RHEL 9.0
11.9
11.9
12.0
RHEL 9.2
11.9
11.9
12.0
Ubuntu 18.04
11.9
11.9
12.0
Ubuntu 20.04
11.9
11.9
12.0
Debian 11
11.9
11.9
12.0
Also refer to:
