Changes to the Tenant Management API
StorageGRID 11.9 uses version 4 of the Tenant Management API. Version 4 deprecates version 3; however, versions 1, 2, and 3 are still supported.
Note You can continue to use deprecated versions of the Tenant Management API with StorageGRID 11.9; however, support for these versions of the API will be removed in a future release of StorageGRID. After upgrading to StorageGRID 11.9, you can deactivate the deprecated APIs by using the PUT /grid/config/management API.
To learn more, go to Understand the Tenant Management API.
New API for bucket capacity limit
You can use the /org/containers/{bucketName}/quota-object-bytes API with GET/PUT operations to get and set the storage capacity limit for a bucket.
