Changes to the Tenant Management API
StorageGRID 11.5 uses version 3 of the Tenant Management API. Version 3 deprecates version 2; however, version 1 and version 2 are still supported.
You can continue to use version 1 and version 2 of the management API with StorageGRID 11.5; however, support for these versions of the API will be removed in a future release of StorageGRID. After upgrading to StorageGRID 11.5, the deprecated v1 and v2 APIs can be deactivated using the PUT /grid/config/management API.
New parameter for tenant Storage Usage API
The GET /org/usage API now has a strictConsistency parameter. To enforce a strong-global consistency when retrieving storage usage information across Storage Nodes, set this parameter to true. When this parameter is set to false (default), StorageGRID attempts to retrieve usage information using strong-global consistency, but falls back to strong-site consistency if strong-global consistency cannot be met.
Related information
