Changes to the Tenant Management API
StorageGRID 11.7 uses version 3 of the Tenant Management API. Version 3 deprecates version 2; however, version 1 and version 2 are still supported.
You can continue to use version 1 and version 2 of the management API with StorageGRID 11.7; however, support for these versions of the API will be removed in a future release of StorageGRID. After upgrading to StorageGRID 11.7, the deprecated v1 and v2 APIs can be deactivated using the PUT /grid/config/management API.
New endpoints for grid federation
You can use the grid-federation-connections API endpoints to list grid federation connections for the current tenant and to clear the last cross-grid replication error for the current tenant and selected grid federation connection.
To learn more, go to Understand the Tenant Management API.
