Restore Prometheus metrics when recovering primary Admin Node
PDF of this doc site
Install and upgrade
Configure and manage
Maintain
Recover nodes and maintain your grid
Creating your file...
Optionally, you can retain the historical metrics maintained by Prometheus on a primary Admin Node that has failed. The Prometheus metrics can only be restored if your StorageGRID system includes another Admin Node.
The recovered Admin Node is installed and running.
The StorageGRID system includes at least two Admin Nodes.
You have the
Passwords.txt
file. -
You have the provisioning passphrase.
If an Admin Node fails, the metrics maintained in the Prometheus database on the Admin Node are lost. When you recover the Admin Node, the software installation process creates a new Prometheus database. After the recovered Admin Node is started, it records metrics as if you had performed a new installation of the StorageGRID system.
If you restored a primary Admin Node and your StorageGRID system has another Admin Node, you can restore the historical metrics by copying the Prometheus database from a non-primary Admin Node (the source Admin Node) to the recovered primary Admin Node. If your system has only a primary Admin Node, you can't restore the Prometheus database.
Copying the Prometheus database might take an hour or more. Some Grid Manager features will be unavailable while services are stopped on the source Admin Node. |
Log in to the source Admin Node:
Enter the following command:
ssh admin@grid_node_IP
Enter the password listed in the
Passwords.txt
file. -
Enter the following command to switch to root:
su -
Passwords.txt
file.
From the source Admin Node, stop the Prometheus service:
service prometheus stop
Complete the following steps on the recovered Admin Node:
Log in to the recovered Admin Node:
Passwords.txt
file. -
su -
Passwords.txt
file.
Stop the Prometheus service:
Add the SSH private key to the SSH agent. Enter:
ssh-add
Enter the SSH Access Password listed in the
Passwords.txt
file. -
Copy the Prometheus database from the source Admin Node to the recovered Admin Node:
/usr/local/prometheus/bin/prometheus-clone-db.sh Source_Admin_Node_IP
When prompted, press Enter to confirm that you want to destroy the new Prometheus database on the recovered Admin Node.
The original Prometheus database and its historical data are copied to the recovered Admin Node. When the copy operation is done, the script starts the recovered Admin Node. The following status appears:
Database cloned, starting services
When you no longer require passwordless access to other servers, remove the private key from the SSH agent. Enter:
ssh-add -D
Restart the Prometheus service on the source Admin Node.
service prometheus start
