      Turn controller identify LED on and off
The blue identify LED on the front and back of the controller can be turned on to help locate the appliance in a data center.
Before you begin
You have the BMC IP address of the controller you want to identify.
Steps
Access the appliance BMC interface.
Select Server Identify. The current status of the identify LED is selected.
Select ON or OFF, and then select Perform Action. When you select ON, the blue identify LEDs light on the front (shown) and rear of the appliance.   If a bezel is installed on the controller, it might be difficult to see the front identify LED.
Turn the LED on and off as needed.
Related information
 PDFs
PDFs
