Update subnets for Grid Network
StorageGRID maintains a list of the network subnets used to communicate between grid nodes on the Grid Network (eth0). These entries include the subnets used for the Grid Network by each site in your StorageGRID system as well as any subnets used for NTP, DNS, LDAP, or other external servers accessed through the Grid Network gateway. When you add grid nodes or a new site in an expansion, you might need to update or add subnets to the Grid Network.
You are signed in to the Grid Manager using a supported web browser.
You have the Maintenance or Root access permission.
You have the provisioning passphrase.
You have the network addresses, in CIDR notation, of the subnets you want to configure.
If you are performing an expansion activity that includes adding a new subnet, you must add a new subnet to the Grid Network subnet list before you start the expansion procedure. Otherwise, you will have to cancel the expansion, add the new subnet, and start the expansion again.
Add a subnet
Select MAINTENANCE > Network > Grid Network.
Select Add another subnet to add a new subnet in CIDR notation.
For example, enter
10.96.104.0/22. -
Enter the provisioning passphrase, and select Save.
Wait until the changes are applied, then download a new Recovery Package.
Select MAINTENANCE > System > Recovery package.
Enter the Provisioning Passphrase.
The Recovery Package file must be secured because it contains encryption keys and passwords that can be used to obtain data from the StorageGRID system. It is also used to recover the primary Admin Node.
The subnets you have specified are configured automatically for your StorageGRID system.
Edit a subnet
Select the subnet you want to edit and make the necessary changes.
Enter the Provisioning passphrase, and select Save.
Select Yes in the confirmation dialog box.
Delete a subnet
Select the delete icon
next to the subnet. -
