Update subnets for Grid Network
StorageGRID maintains a list of the network subnets used to communicate between grid nodes on the Grid Network (eth0). These entries include the subnets used for the Grid Network by each site in your StorageGRID system as well as any subnets used for NTP, DNS, LDAP, or other external servers accessed through the Grid Network gateway. When you add grid nodes or a new site in an expansion, you might need to update or add subnets to the Grid Network.
You must be signed in to the Grid Manager using a supported web browser.
You must have the Maintenance or Root Access permission.
You must have the provisioning passphrase.
You must have the network addresses, in CIDR notation, of the subnets you want to configure.
If you are performing an expansion activity that includes adding a new subnet, you must add the new Grid subnet before you start the expansion procedure.
Select MAINTENANCE > Network > Grid Network.
In the Subnets list, click the plus sign to add a new subnet in CIDR notation.
For example, enter
10.96.104.0/22. -
Enter the provisioning passphrase, and click Save.
The subnets you have specified are configured automatically for your StorageGRID system.
Download a new Recovery Package from the Grid Manager.
Select MAINTENANCE > System > Recovery package.
Enter the provisioning passphrase.
