E5600SG controller seven-segment display codes
The seven-segment display on the E5600SG controller shows status and error codes while the appliance powers up and while the hardware is initializing. You can use these codes to determine status and troubleshoot errors.
When reviewing status and error codes on the E5600SG controller, you should look at the following types of codes:
General boot-up codes
Represent the standard boot-up events.
Normal boot-up codes
Represent the normal boot-up events that occur in the appliance.
Error codes
Indicate issues during the boot-up events.
StorageGRID controls only the following LEDs on the E5600SG controller and only after the StorageGRID Appliance Installer has started:
Service Action Allowed LED
Service Action Required LED
Seven-segment display
The decimal points on the seven-segment display are not used by the StorageGRID appliance:
The upper decimal point adjacent to the least significant digit is the platform diagnostic LED.
This is turned on during reset and initial hardware configuration. Otherwise, it is turned off.
The lower decimal point adjacent to the most significant digit is turned off.
To diagnose other issues, you might want to look at these resources:
To see all other hardware and environmental diagnostic information, see the E-Series operating system hardware diagnostics.
This includes looking for hardware issues such as power, temperature, and disk drives. The appliance relies on the E-Series operating system to monitor all platform environmental statuses.
To determine firmware and driver issues, look at the link lights on the SAS and network ports.
For details, see the E-Series E5600 documentation.
During boot-up or after a hard reset of the hardware, the Service Action Allowed and the Service Action Required LEDs come on while the hardware is initializing. The seven-segment display shows a sequence of codes that are the same for E-Series hardware and not specific to the E5600SG controller.
During boot-up, the Field Programmable Gate Array (FPGA) controls the functions and initialization on the hardware.
| Code | Indication |
19 |
FPGA initialization. |
68 |
FPGA initialization.This is a quick succession of codes. |
AA |
Platform BIOS booting. |
FF |
Bios boot-up complete.This is an intermediate state before E5600SG controller initializes and manages LEDs to indicate status. |
After the AA and FF codes appear, either the normal boot-up codes appear or error codes appear. Additionally, the Service Action Allowed and the Service Action Required LEDs are turned off.
These codes represent the normal boot-up events that occur in the appliance, in chronological order.
| Code | Indication |
HI |
The master boot script has started. |
PP |
The platform FPGA firmware is checking for updates. |
HP |
The host interface card (HIC) is checking for updates. |
RB |
After firmware updates, the system is rebooting, if necessary. |
FP |
The firmware update checks have been completed. Starting the process (utmagent) to communicate with and manage the E2700 controller. This process facilitates appliance provisioning. |
HE |
The system is synchronizing with the E-Series operating system. |
HC |
The StorageGRID installation is being checked. |
HO |
Installation management and active interfacing are occurring. |
HA |
The Linux operating system and StorageGRID are running. |
E5600SG controller error codes
These codes represent error conditions that might be shown on the E5600SG controller as the appliance boots up. Additional two-digit hexadecimal codes are displayed if specific low-level hardware errors occur. If any of these codes persists for more than a second or two, or if you are unable to resolve the error by following one of the prescribed troubleshooting procedures, contact technical support.
| Code | Indication |
22 |
No master boot record found on any boot device. |
23 |
No SATA drive installed. |
2A, 2B |
Stuck bus, unable to read DIMM SPD data. |
40 |
Invalid DIMMs. |
41 |
Invalid DIMMs. |
42 |
Memory test failed. |
51 |
SPD reading failure. |
92 to 96 |
PCI bus initialization. |
A0 to A3 |
SATA drive initialization. |
AB |
Alternate boot code. |
AE |
Booting OS. |
EA |
DDR3 training failed. |
E8 |
No memory installed. |
EU |
The installation script was not found. |
EP |
"ManageSGA" code indicates that pregrid communication with the E2700 controller failed. |
