Reset the Store Failure Count for S3 API connection
Contributors netapp-madkat netapp-perveilerk netapp-lhalbert
If your Archive Node connects to an archival storage system through the S3 API, you can reset the Store Failure Count, which can be used to clear the ARVF (Store Failures) alarm.
What you’ll need
  • You are signed in to the Grid Manager using a supported web browser.
  • You have specific access permissions.
Steps
  1. Select SUPPORT > Tools > Grid topology.
  2. Select Archive Node > ARC > Store.
  3. Select Configuration > Main.
    Configure store settings for S3 API connection
  4. Select Reset Store Failure Count.
  5. Select Apply Changes.
    The Store Failures attribute resets to zero.
