      Add users to a local group
You can add users to a local group as needed.
What you'll need
You must be signed in to the Tenant Manager using a supported web browser.
You must belong to a user group that has the Root Access permission.
Steps
Select ACCESS MANAGEMENT > Groups.
Select the name of the local group you want to add users to. Alternatively, you can select Actions > View group details. The group details page appears.
Select Users, and then select Add users.
Select the users you want to add to the group, and then select Add users.   A confirmation message appears in the upper right corner of the page. Changes might take up to 15 minutes to take effect because of caching.
 PDFs
PDFs
