Locate controller in data center
PDF of this doc site
Install and maintain appliance hardware
Install and upgrade software
Perform system administration
Monitor and maintain StorageGRID
Recover and maintain
Grid node recovery procedures
Creating your file...
Locate the controller so that you can perform hardware maintenance or upgrades.
You have determined which controller requires maintenance.
(Optional) To help locate the controller in your data center, turn on the blue identify LED.
Find the controller requiring maintenance in the data center.
Look for a lit blue identify LED on the front or rear of the controller.
The front identify LED is behind the controller front bezel and might be difficult to see if the bezel is installed.
Check the tags attached to the front of each controller for a matching part number.
Remove the controller front bezel, if one is installed, to access the front panel controls and indicators.
Optional: Turn off the blue identify LED if you used it to locate the controller.
Press the identify LED switch on the controller front panel.
Use the controller BMC interface.
