Gather required materials
Before performing a grid node decommission, you must obtain the following information.
| Item | Notes |
Recovery Package   |
You must download the most recent Recovery Package   |
This file contains the passwords required to access grid nodes on the command line and is included in the Recovery Package.  |
Provisioning passphrase  |
The passphrase is created and documented when the StorageGRID system is first installed. The provisioning passphrase is not in the   |
Description of StorageGRID system's topology before decommissioning  |
If available, obtain any documentation that describes the system's current topology.  |
