Check storage state after recovering Storage Node system drive
PDF of this doc site
Install and maintain appliance hardware
Install and upgrade software
Perform system administration
Monitor and maintain StorageGRID
Recover and maintain
Grid node recovery procedures
Creating your file...
After recovering the system drive for a Storage Node, you must verify that the desired state of the Storage Node is set to online and ensure that the state will be online by default whenever the Storage Node server is restarted.
You must be signed in to the Grid Manager using a supported web browser.
The Storage Node has been recovered, and data recovery is complete.
Select SUPPORT > Tools > Grid topology.
Check the values of Recovered Storage Node > LDR > Storage > Storage State — Desired and Storage State — Current.
The value of both attributes should be Online.
If the Storage State — Desired is set to Read-only, complete the following steps:
Click the Configuration tab.
From the Storage State — Desired drop-down list, select Online.
Click Apply Changes.
Click the Overview tab and confirm that the values of Storage State — Desired and Storage State — Current are updated to Online.
