Check storage state after recovering a StorageGRID Storage Node system drive
After recovering the system drive for a Storage Node, you must verify that the desired state of the Storage Node is set to online and ensure that the state will be online by default whenever the Storage Node server is restarted.
Before you begin
You are signed in to the Grid Manager using a supported web browser.
The Storage Node has been recovered, and data recovery is complete.
Steps
Select Nodes > Storage Node > Tasks.
If the Storage state drop-down list is set to Read-only or Offline, select Online.
Select Save.
