Create a tenant account for FabricPool
You must create a tenant account in the Grid Manager for FabricPool use.
You are signed in to the Grid Manager using a supported web browser.
You have specific access permissions.
Tenant accounts allow client applications to store and retrieve objects on StorageGRID. Each tenant account has its own account ID, authorized groups and users, buckets, and objects.
You can use the same tenant account for multiple ONTAP clusters. Or, you can create a dedicated tenant account for each ONTAP cluster as required.
These instructions assume that you have configured single sign-on (SSO) for the Grid Manager. If SSO is not enabled, use these instructions to create a tenant account instead. |
Select TENANTS.
Select Create.
Enter a display name and a description.
Select S3.
Leave the Storage quota field blank.
Select Allow platform services to enable the use of platform services.
If platform services are enabled, a tenant can use features, such as CloudMirror replication, that access external services.
Do not select Use own identity source.
Do not select Allow S3 Select.
Select an existing federated group from the Grid Manager to have the initial Root Access permission for the tenant.
Select Create tenant.
