Select node recovery procedure
Contributors netapp-lhalbert netapp-perveilerk
You must select the correct recovery procedure for the type of node that has failed.
Grid node Recovery procedure
More than one Storage Node
Contact technical support. If more than one Storage Node has failed, technical support must assist with recovery to prevent database inconsistencies that could lead to data loss. A site recovery procedure might be required.
A single Storage Node
The Storage Node recovery procedure depends on the type and duration of the failure.
Admin Node
The Admin Node procedure depends on whether you need to recover the primary Admin Node or a non-primary Admin Node.
Gateway Node
Archive Node
Note If a server that is hosting more than one grid node fails, you can recover the nodes in any order. However, if the failed server is hosting the primary Admin Node, you must recover that node first. Recovering the primary Admin Node first prevents other node recoveries from halting as they wait to contact the primary Admin Node.
