Remove custom alert rules
Contributors netapp-madkat
You can remove a custom alert rule if you no longer want to use it.
What you’ll need
  • You are signed in to the Grid Manager using a supported web browser.
  • You have the Manage Alerts or Root Access permission.
Steps
  1. Select ALERTS > Rules.
    The Alert Rules page appears.
  2. Select the radio button for the custom alert rule you want to remove.
    You cannot remove a default alert rule.
  3. Select Remove custom rule.
    A confirmation dialog box appears.
  4. Select OK to remove the alert rule.
    Any active instances of the alert will be resolved within 10 minutes.
