Remove custom alert rules in StorageGRID
Contributors netapp-pcarriga netapp-lhalbert
You can remove a custom alert rule if you no longer want to use it.
Before you begin
Steps
  1. Select Alerts > Rules.
    The Alert Rules page appears.
  2. Select the radio button for the custom alert rule you want to remove.
    You can't remove a default alert rule.
  3. Select Remove custom rule.
    A confirmation dialog box appears.
  4. Select OK to remove the alert rule.
    Any active instances of the alert will be resolved within 10 minutes.
