Learn about lost and missing object data in StorageGRID
Contributors netapp-lhalbert netapp-pcarriga netapp-jsnyder
Objects can be retrieved for several reasons, including read requests from a client application, background verifications of replicated object data, ILM re-evaluations, and the restoration of object data during the recovery of a Storage Node.
The StorageGRID system uses location information in an object's metadata to determine from which location to retrieve the object. If a copy of the object isn't found in the expected location, the system attempts to retrieve another copy of the object from elsewhere in the system, assuming that the ILM policy contains a rule to make two or more copies of the object.
If this retrieval is successful, the StorageGRID system replaces the missing copy of the object. Otherwise, the Objects potentially lost alert is triggered, as follows:
  • For replicated copies, if another copy can't be retrieved, the object is considered lost, and the alert is triggered.
  • For erasure-coded copies, if a copy can't be retrieved from the expected location, the Corrupt Copies Detected (ECOR) attribute is incremented by one before an attempt is made to retrieve a copy from another location. If no other copy is found, the alert is triggered.
You should investigate all Objects potentially lost alerts immediately to determine the root cause of the loss and to determine if the object might still exist in an offline, or otherwise currently unavailable, Storage Nodes. See Investigate potentially lost objects. Lost object alerts might be falsely triggered out of caution.
In the case where object data without copies is lost, there is no recovery solution. However, you must reset the Objects potentially lost counter to prevent known lost objects from masking any new lost objects.
