Recover from StorageGRID Storage Node failures
Contributors netapp-lhalbert netapp-pcarriga netapp-perveilerk
The procedure for recovering a failed Storage Node depends on the type of failure and the type of Storage Node that has failed.
Use this table to select the recovery procedure for a failed Storage Node.
Issue Action Notes
More than one Storage Node has failed.
Contact technical support.
If more than one Storage Node has failed, technical support must assist with recovery to prevent Cassandra database inconsistencies that could lead to data loss. A site recovery procedure might be required.
Technical support can determine when it's safe to begin recovery of a second Storage Node.
Note: If more than one Storage Node that contains the ADC service fails at a site, any pending platform service requests for that site will be lost.
More than one Storage Node at a site has failed or an entire site has failed.
Contact technical support. It might be necessary to perform a site recovery procedure.
Technical support will assess your situation and develop a recovery plan. See How technical support recovers a site.
An appliance Storage Node has failed.
The recovery procedure for appliance Storage Nodes is the same for all failures.
One or more storage volumes have failed, but the system drive is intact
This procedure is used for software-based Storage Nodes.
The system drive has failed.
The node replacement procedure depends on the deployment platform and on whether any storage volumes have also failed.
Note Some StorageGRID recovery procedures use Reaper to handle Cassandra repairs. Repairs occur automatically as soon as the related or required services have started. You might notice script output that mentions "reaper" or "Cassandra repair." If you see an error message indicating the repair has failed, run the command indicated in the error message.
