How S3 bucket lifecycle and ILM policy interact in StorageGRID
Contributors netapp-pcarriga netapp-jsnyder netapp-perveilerk
Depending on your lifecycle configuration, objects follow the retention settings of either the S3 bucket lifecycle or an ILM policy.
Example of bucket lifecycle taking priority over ILM policy
ILM policy
  • Rule based on noncurrent-time reference: On Day 0, keep X copies for 20 days
  • Rule based on ingest-time reference (default): On Day 0, keep X copies for 50 days
Bucket Lifecycle
"Filter": {"Prefix": "docs/"}, "Expiration": {"Days": 100}, "NoncurrentVersionExpiration": {"NoncurrentDays": 5}
Result
  • An object named "docs/text" is ingested. It matches the bucket lifecycle filter of "docs/" prefix.
    • After 100 days a delete-marker is created and "docs/text" becomes noncurrent.
    • After 5 days, a total of 105 days since ingest, "docs/text" is deleted.
    • After 95 days, a total of 200 days since the ingest and 100 days since the delete-marker was created, the expired delete-marker is deleted.
  • An object named "video/movie" is ingested. It does not match the filter and uses the ILM retention policy.
    • After 50 days a delete-marker is created and "video/movie" becomes noncurrent.
    • After 20 days, a total of 70 days since the ingest, "video/movie" is deleted.
    • After 30 days, a total of 100 days since the ingest and 50 days since the delete-marker was created, the expired delete-marker is deleted.
Example of bucket lifecycle implicitly keeping-forever
ILM policy
Bucket Lifecycle
"Filter": {"Prefix": "docs/"}, "Expiration": {"ExpiredObjectDeleteMarker": true}
Result
    The Expiration action applies only to expired delete markers, which implies keeping everything else forever (starting with "docs/").
    Delete markers that start with "docs/" are removed when they become expired.
Example of using bucket lifecycle to duplicate ILM and clean up expired delete markers
ILM policy
  • Rule based on ingest-time reference (default): On Day 0, keep X copies forever
Bucket Lifecycle
"Filter": {}, "Expiration": {"ExpiredObjectDeleteMarker": true}, "NoncurrentVersionExpiration": {"NoncurrentDays": 20}
Result
  • The ILM policy is duplicated in the bucket lifecycle.
    • The ILM policy's forever rule is designed for removing objects manually and cleaning up noncurrent versions after 20 days. Consequently, the ingest-time rule will keep expired delete markers forever.
    • The bucket lifecycle duplicates the ILM policy's behavior while adding "ExpiredObjectDeleteMarker": true, which removes delete markers once they are expired
  • An object is ingested. No filter means that the bucket lifecycle applies to all objects and overrides the ILM retention settings.
    • When a tenant issues an object delete request, a delete-marker is created and the object becomes noncurrent.
    • After 20 days, the noncurrent object is deleted and the delete-marker becomes expired.
    • Shortly after, the expired delete-marker is deleted.
