Configure CloudMirror replication in StorageGRID
Contributors netapp-lhalbert netapp-pcarriga netapp-perveilerk
To enable CloudMirror replication for a bucket, you create and apply a valid bucket replication configuration XML.
Before you begin
  • Platform services were enabled for your tenant account by a StorageGRID administrator.
  • You have already created a bucket to act as the replication source.
  • The endpoint that you intend to use as a destination for CloudMirror replication already exists, and you have its URN.
  • You belong to a user group that has the Manage all buckets or Root access permission. These permissions override the permission settings in group or bucket policies when configuring the bucket using the Tenant Manager.
About this task
CloudMirror replication copies objects from a source bucket to a destination bucket that is specified in an endpoint.
For general information about bucket replication and how to configure it, see Amazon Simple Storage Service (S3) documentation: Replicating objects. For information about how StorageGRID implements GetBucketReplication, DeleteBucketReplication, and PutBucketReplication, see the Operations on buckets.
Note CloudMirror replication has important similarities and differences with the cross-grid replication feature. To learn more, see Compare cross-grid replication and CloudMirror replication.
Note the following requirements and characteristics when configuring CloudMirror replication:
  • When you create and apply a valid bucket replication configuration XML, it must use the URN of an S3 bucket endpoint for each destination.
  • Replication is only supported for source or destination buckets with S3 Object Lock enabled for Amazon S3 or StorageGRID S3 buckets. The object lock headers are not replicated to the destination object.
  • If you enable CloudMirror replication on a bucket that contains objects, new objects added to the bucket are replicated, but the existing objects in the bucket aren't replicated. You must update existing objects to trigger replication.
  • If you enable S3 Object Lock on the destination bucket after you configure CloudMirror replication, you might have to re-save the endpoint to allow replication to resume.
  • If you specify a storage class in the replication configuration XML, StorageGRID uses that class when performing operations against the destination S3 endpoint. The destination endpoint must also support the specified storage class. Be sure to follow any recommendations provided by the destination system vendor.
Steps
  1. Enable replication for your source bucket:
    • Use a text editor to create the replication configuration XML required to enable replication, as specified in the S3 replication API.
    • When configuring the XML:
      • Note that StorageGRID only supports V1 of the replication configuration. This means that StorageGRID does not support the use of the Filter element for rules, and follows V1 conventions for deletion of object versions. See the Amazon documentation on replication configuration for details.
      • Use the URN of an S3 bucket endpoint as the destination.
      • Optionally add the <StorageClass> element, and specify one of the following:
        • STANDARD: The default storage class. If you don't specify a storage class when you upload an object, the STANDARD storage class is used.
        • STANDARD_IA: (Standard - infrequent access.) Use this storage class for data that is accessed less frequently, but that still requires rapid access when needed.
        • REDUCED_REDUNDANCY: Use this storage class for noncritical, reproducible data that can be stored with less redundancy than the STANDARD storage class.
      • If you specify a Role in the configuration XML it will be ignored. This value is not used by StorageGRID.
        <ReplicationConfiguration>
            <Role></Role>
            <Rule>
                <Status>Enabled</Status>
                <Prefix>2020</Prefix>
                <Destination>
                   <Bucket>urn:sgws:s3:::2017-records</Bucket>
                   <StorageClass>STANDARD</StorageClass>
                 </Destination>
             </Rule>
        </ReplicationConfiguration>
  2. Select View buckets from the dashboard, or select STORAGE (S3) > Buckets.
  3. Select the name of the source bucket.
    The bucket details page appears.
  4. Select Platform services > Replication.
  5. Select the Enable replication checkbox.
  6. Paste the replication configuration XML into the text box, and select Save changes.
    Note Platform services must be enabled for each tenant account by a StorageGRID administrator using the Grid Manager or Grid Management API. Contact your StorageGRID administrator if an error occurs when you save the configuration XML.
  7. Verify that replication is configured correctly:
    1. Add an object to the source bucket that meets the requirements for replication as specified in the replication configuration.
      In the example shown earlier, objects that match the prefix "2020" are replicated.
    2. Confirm that the object has been replicated to the destination bucket.
      For small objects, replication happens quickly.
Related information
Create platform services endpoint
