Specify a URN for a StorageGRID platform services endpoint
When you create a platform services endpoint, you must specify a Unique Resource Name (URN). You will use the URN to reference the endpoint when you create a configuration XML for the platform service. The URN for each endpoint must be unique.
StorageGRID validates platform services endpoints as you create them. Before you create a platform services endpoint, confirm that the resource specified in the endpoint exists and that it can be reached.
URN elements
The URN for a platform services endpoint must start with either arn:aws or urn:mysite, as follows:
If the service is hosted on Amazon Web Services (AWS), use
arn:aws -
If the service is hosted on Google Cloud Platform (GCP), use
arn:aws -
If the service is hosted locally, use
urn:mysite
For example, if you are specifying the URN for a CloudMirror endpoint hosted on StorageGRID, the URN might begin with urn:sgws.
The next element of the URN specifies the type of platform service, as follows:
| Service | Type |
CloudMirror replication |
Notifications |
Search integration |
For example, to continue specifying the URN for a CloudMirror endpoint hosted on StorageGRID, you would add s3 to get urn:sgws:s3.
For most endpoints, the final element of the URN identifies the specific target resource at the destination URI, for example, sns-topic-name.
For webhook endpoints, the target resource is the destination URI itself.
| Service | Specific resource |
Notifications |
Note: For webhook endpoints, the final element of the URN can be any string, as long as the URN of the endpoint is unique. |
Note: If the Elasticsearch cluster is not configured to create indexes automatically, you must create the index manually before you create the endpoint. |
URNs for services hosted on AWS and GCP
For AWS and GCP entities, the complete URN is a valid AWS ARN. For example:
CloudMirror replication:
arn:aws:s3:::bucket-name
Notifications:
arn:aws:sns:region:account-id:topic-name
Search integration:
arn:aws:es:region:account-id:domain/domain-name/index-name/type-name
For an AWS search integration endpoint, the domain-namemust include the literal stringdomain/, as shown here.
URNs for locally-hosted services
When using locally-hosted services instead of cloud services, you can specify the URN in any way that creates a valid and unique URN, as long as the URN includes the required elements in the third and final positions. You can leave the elements indicated by optional blank, or you can specify them in any way that helps you identify the resource and make the URN unique. For example:
urn:mysite:s3:::bucket-name
For a CloudMirror endpoint hosted on StorageGRID, you can specify a valid URN that begins with
urn:sgws:urn:sgws:s3:::bucket-name
Notifications:
Specify an Amazon Simple Notification Service endpoint:
urn:aws:sns:region:account-id:sns-topic-name
Specify a Kafka endpoint:
urn::kafka:::kafka-topic-name
Optionally, you can include mysitewhen specifying a Kafka endpoint:urn:mysite:kafka:::kafka-topic-nameSpecify a webhook endpoint:
urn:mysite:webhook:::webhook-name
Search integration:
urn:mysite:es:::domain-name/index-name/type-name
For locally-hosted search integration endpoints, the domain-nameelement can be any string as long as the URN of the endpoint is unique.
