Select Start Recovery to configure StorageGRID Gateway Node
Contributors netapp-lhalbert netapp-pcarriga netapp-perveilerk
After replacing a Gateway Node, you must select Start Recovery in the Grid Manager to configure the new node as a replacement for the failed node.
Before you begin
Steps
  1. From the Grid Manager, select Maintenance > Tasks > Node recovery.
  2. Select the grid node you want to recover in the Pending Nodes list.
    Nodes appear in the list after they fail, but you can't select a node until it has been reinstalled and is ready for recovery.
  3. Enter the Provisioning passphrase.
  4. Select Start recovery.
    screenshot showing the Maintenance > Recovery page
  5. Monitor the progress of the recovery in the Recovering Grid Node table.
    Note While the recovery procedure is running, you can select Reset to start a new recovery. A dialog box appears, indicating that the node will be left in an indeterminate state if you reset the procedure.
    If you want to retry the recovery after resetting the procedure, you must restore the node to a pre-installed state, as follows:
    • VMware: Delete the deployed virtual grid node. Then, when you are ready to restart the recovery, redeploy the node.
    • Linux: Restart the node by running this command on the Linux host: storagegrid node force-recovery node-name
    • Appliance: If you want to retry the recovery after resetting the procedure, you must restore the appliance node to a pre-installed state by running sgareinstall on the node. See Prepare appliance for reinstallation (platform replacement only).
