IP addresses and ports for StorageGRID client connections
Contributors netapp-lhalbert netapp-pcarriga
To store or retrieve objects, S3 client applications connect to the Load Balancer service, which is included on all Admin Nodes and Gateway Nodes, or to the Local Distribution Router (LDR) service, which is included on all Storage Nodes.
Client applications can connect to StorageGRID using the IP address of a grid node and the port number of the service on that node. Optionally, you can create high availability (HA) groups of load-balancing nodes to provide highly available connections that use virtual IP (VIP) addresses. If you want to connect to StorageGRID using a fully qualified domain name (FQDN) instead of an IP or VIP address, you can configure DNS entries.
This table summarizes the different ways that clients can connect to StorageGRID and the IP addresses and ports that are used for each type of connection. If you have already created load balancer endpoints and high availability (HA) groups, see Where to find IP addresses to locate these values in the Grid Manager.
Where connection is made Service that client connects to IP address Port
HA group
Load Balancer
Virtual IP address of an HA group
Port assigned to the load balancer endpoint
Admin Node
Load Balancer
IP address of the Admin Node
Gateway Node
Load Balancer
IP address of the Gateway Node
Storage Node
LDR
IP address of Storage Node
Default S3 ports:
  • HTTPS: 18082
  • HTTP: 18084
Example URLs
To connect a client application to the Load Balancer endpoint of an HA group of Gateway Nodes, use a URL structured as shown below:
https://VIP-of-HA-group:LB-endpoint-port
For example, if the virtual IP address of the HA group is 192.0.2.5 and the port number of the load balancer endpoint is 10443, then an application could use the following URL to connect to StorageGRID:
https://192.0.2.5:10443
  1. Sign in to the Grid Manager using a supported web browser.
  2. To find the IP address of a grid node:
    1. Select Nodes.
    2. Select the Admin Node, Gateway Node, or Storage Node to which you want to connect.
    3. Select the Overview tab.
    4. In the Node Information section, note the IP addresses for the node.
    5. Select Show more to view IPv6 addresses and interface mappings.
      You can establish connections from client applications to any of the IP addresses in the list:
      • eth0: Grid Network
      • eth1: Admin Network (optional)
      • eth2: Client Network (optional)
        Note If you are viewing an Admin Node or a Gateway Node and it is the active node in a high availability group, the virtual IP address of the HA group is shown on eth2.
  3. To find the virtual IP address of a high availability group:
    1. Select Configuration > Network > High availability groups.
    2. In the table, note the virtual IP address of the HA group.
  4. To find the port number of a Load Balancer endpoint:
    1. Select Configuration > Network > Load balancer endpoints.
    2. Note the port number for the endpoint you want to use.
      Note If the port number is 80 or 443, the endpoint is configured only on Gateway Nodes, because those ports are reserved on Admin Nodes. All other ports are configured on both Gateway Nodes and Admin Nodes.
    3. Select the name of the endpoint from the table.
    4. Confirm that the Client type (S3) matches the client application that will use the endpoint.
