Recover the StorageGRID primary Admin Node using the same primary Admin Node
You must complete a specific set of tasks to recover from a primary Admin Node failure. The primary Admin Node hosts the Configuration Management Node (CMN) service for the grid.
You must repair or replace a failed primary Admin Node promptly or you might not be able to perform certain maintenance procedures. |
Follow these high-level steps to recover a primary Admin Node:
