Recover from primary StorageGRID Admin Node failures
You must complete a specific set of tasks to recover from a primary Admin Node failure. The primary Admin Node hosts the Configuration Management Node (CMN) service for the grid.
Caution You must repair or replace a failed primary Admin Node promptly or you might not be able to perform certain maintenance procedures.
Follow these high-level steps to recover a primary Admin Node:
