Determine hotfix requirement for primary Admin Node in StorageGRID
After recovering a primary admin node, determine if you need to apply a hotfix.
Before you begin
Primary admin node recovery is complete.
Steps
Sign in to the Grid Manager using a supported web browser.
Select Nodes.
From the list on the left, select the primary Admin Node.
On the Overview tab, note the version displayed in the Software Version field.
Select any other grid node.
If the versions displayed in the Software Version fields are the same, you don't need to apply a hotfix.
If the versions displayed in the Software Version fields are different, you must apply a hotfix to update the recovered primary Admin Node to the same version.
