StorageGRID Admin or Gateway Node decommissioning considerations
Contributors netapp-pcarriga netapp-lhalbert
Review the considerations for decommissioning an Admin Node or Gateway Node.
Considerations for Admin Node
  • You can't decommission the primary Admin Node.
  • You can't decommission an Admin Node if one of its network interfaces is part of a high availability (HA) group. You must first remove the network interfaces from the HA group. See the instructions for managing HA groups.
  • As required, you can safely change ILM policies while decommissioning an Admin Node.
  • If you decommission an Admin Node and single sign-on (SSO) is enabled for your StorageGRID system, you must remember to remove the node's relying party trust from Active Directory Federation Services (AD FS).
  • If you use grid federation, ensure that the IP address of the node you are decommissioning was not specified for a grid federation connection.
  • When you decommission a disconnected Admin Node, you will lose the audit logs from that node; however, these logs should also exist on the primary Admin Node.
Considerations for Gateway Node
  • You can't decommission a Gateway Node if one of its network interfaces is part of a high availability (HA) group. You must first remove the network interfaces from the HA group. See the instructions for managing HA groups.
  • As required, you can safely change ILM policies while decommissioning a Gateway Node.
  • You can safely decommission a Gateway Node while it is disconnected.
