StorageGRID
Considerations for Admin Node or Gateway Node decommission
Contributors netapp-pcelmer netapp-perveilerk
Review the following considerations before decommissioning an Admin Node or a Gateway Node.
  • The decommission procedure requires exclusive access to some system resources, so you must confirm that no other maintenance procedures are running.
  • You cannot decommission the primary Admin Node.
  • You cannot decommission an Admin Node or a Gateway Node if one of its network interfaces is part of a high availability (HA) group. You must first remove the network interfaces from the HA group. See the instructions for administering StorageGRID.
  • As required, you can safely change the ILM policy while decommissioning a Gateway Node or an Admin Node.
  • If you decommission an Admin Node and single sign-on (SSO) is enabled for your StorageGRID system, you must remember to remove the node’s relying party trust from Active Directory Federation Services (AD FS).
Related information
Administer StorageGRID
