Considerations for Admin Node or Gateway Node decommission
PDF of this doc site
Install and upgrade
Configure and manage
Maintain
Recover nodes and maintain your grid
Creating your file...
Review the following considerations before decommissioning an Admin Node or a Gateway Node.
The decommission procedure requires exclusive access to some system resources, so you must confirm that no other maintenance procedures are running.
You can't decommission the primary Admin Node.
You can't decommission an Admin Node or a Gateway Node if one of its network interfaces is part of a high availability (HA) group. You must first remove the network interfaces from the HA group. See the instructions for managing HA groups.
As required, you can safely change the ILM policy while decommissioning a Gateway Node or an Admin Node.
If you decommission an Admin Node and single sign-on (SSO) is enabled for your StorageGRID system, you must remember to remove the node's relying party trust from Active Directory Federation Services (AD FS).
If you use grid federation, ensure that the IP address of the node you are decommissioning was not specified for a grid federation connection.
