Access StorageGRID Appliance Installer
You must access the StorageGRID Appliance Installer to verify the installer version and configure the connections between the appliance and the three StorageGRID networks: the Grid Network, the Admin Network (optional), and the Client Network (optional).
You are using any management client that can connect to the StorageGRID Admin Network, or you have a service laptop.
The client or service laptop has a supported web browser.
The services appliance or storage appliance controller is connected to all of the StorageGRID networks you plan to use.
You know the IP address, gateway, and subnet for the services appliance or storage appliance controller on these networks.
You have configured the network switches you plan to use.
To initially access the StorageGRID Appliance Installer, you can use the DHCP-assigned IP address for the Admin Network port on the services appliance or storage appliance controller (assuming it is connected to the Admin Network), or you can connect a service laptop directly to the services appliance or storage appliance controller.
If possible, use the DHCP address for the Admin Network port on the services appliance or storage appliance controller. The Admin Network port is highlighted in the following figure. (Use the IP address on the Grid Network if the Admin Network is not connected.)
SGF6112
SG6000-CN
E5700SGFor the E5700SG, you can do either of the following:
Look at the seven-segment display on the E5700SG controller. If management port 1 and 10/25-GbE ports 2 and 4 on the E5700SG controller are connected to networks with DHCP servers, the controller attempts to obtain dynamically assigned IP addresses when you power on the enclosure. After the controller has completed the power-on process, its seven-segment display shows HO, followed by a repeating sequence of two numbers.
HO -- IP address for Admin Network -- IP address for Grid Network HO
In the sequence:
The first set of numbers is the DHCP address for the appliance Storage Node on the Admin Network, if it is connected. This IP address is assigned to management port 1 on the E5700SG controller.
The second set of numbers is the DHCP address for the appliance Storage Node on the Grid Network. This IP address is assigned to 10/25-GbE ports 2 and 4 when you first apply power to the appliance.
If an IP address could not be assigned using DHCP, 0.0.0.0 is displayed.
SG100
SG1000
Locate the MAC address label on the front of the services appliance or storage appliance, and determine the MAC address for the Admin Network port.
The MAC address label lists the MAC address for the BMC management port.
To determine the MAC address for the Admin Network port, add 2 to the hexadecimal number on the label. For example, if the MAC address on the label ends in 09, the MAC address for the Admin Port would end in 0B. If the MAC address on the label ends in (y)FF, the MAC address for the Admin Port would end in (y+1)01. You can easily make this calculation by opening Calculator in Windows, setting it to Programmer mode, selecting Hex, typing the MAC address, then typing + 2 =.
Provide the MAC address to your network administrator, so they can look up the DHCP address for the appliance on the Admin Network.
From the client, enter this URL for the StorageGRID Appliance Installer:
https://Appliance_IP:8443For
Appliance_IP, use the DHCP address (use the IP address for the Admin Network if you have it). -
If you are prompted with a security alert, view and install the certificate using the browser's installation wizard.
The alert will not appear the next time you access this URL.
The StorageGRID Appliance Installer Home page appears. The information and messages shown when you first access this page depend on how your appliance is currently connected to StorageGRID networks. Error messages might appear that will be resolved in later steps.
If you can't obtain an IP address using DHCP, you can use a link-local connection.
SGF6112Connect a service laptop directly to the rightmost RJ-45 port on the appliance, using an Ethernet cable.
SG6000-CNConnect a service laptop directly to the rightmost RJ-45 port on the SG6000-CN controller, using an Ethernet cable.
E5700SGConnect the service laptop to management port 2 on the E5700SG controller, using an Ethernet cable.
SG100Connect a service laptop directly to the rightmost RJ-45 port on the services appliance, using an Ethernet cable.
SG1000Connect a service laptop directly to the rightmost RJ-45 port on the services appliance, using an Ethernet cable.
Open a web browser on the service laptop.
Enter this URL for the StorageGRID Appliance Installer:
https://169.254.0.1:8443The StorageGRID Appliance Installer Home page appears. The information and messages shown when you first access this page depend on how your appliance is currently connected to StorageGRID networks. Error messages might appear that will be resolved in later steps.
If you can't access the Home page over a link-local connection, configure the service laptop IP address as 169.254.0.2, and try again.
After accessing the StorageGRID Appliance Installer:
Verify that the StorageGRID Appliance Installer version on the appliance matches the software version installed on your StorageGRID system. Upgrade StorageGRID Appliance Installer, if necessary.
Review any messages displayed on the StorageGRID Appliance Installer Home page and configure the link configuration and the IP configuration, as required.
