Linux: Add direct-attached or SAN volumes to Storage Node
If a Storage Node includes fewer than 16 storage volumes, you can increase its capacity by adding new block storage devices, making them visible to the Linux hosts, and adding the new block device mappings to the StorageGRID configuration file used for the Storage Node.
You have access to the instructions for installing StorageGRID for your Linux platform.
You have the
Passwords.txtfile. -
You have specific access permissions.
Don't attempt to add storage volumes to a Storage Node while a software upgrade, recovery procedure, or another expansion procedure is active. |
The Storage Node is unavailable for a brief time when you add storage volumes. You should perform this procedure on one Storage Node at a time to avoid impacting client-facing grid services.
Install the new storage hardware.
For more information, see the documentation provided by your hardware vendor.
Create new block storage volumes of the desired sizes.
Attach the new drives and update the RAID controller configuration as needed, or allocate the new SAN LUNs on the shared storage arrays and allow the Linux host to access them.
Use the same persistent naming scheme you used for the storage volumes on the existing Storage Node.
If you use the StorageGRID node migration feature, make the new volumes visible to other Linux hosts that are migration targets for this Storage Node. For more information, see the instructions for installing StorageGRID for your Linux platform.
Log in to the Linux host supporting the Storage Node as root or with an account that has sudo permission.
Confirm that the new storage volumes are visible on the Linux host.
You might have to rescan for devices.
Run the following command to temporarily disable the Storage Node:
sudo storagegrid node stop <node-name> -
Using a text editor such as vim or pico, edit the node configuration file for the Storage Node, which can be found at
/etc/storagegrid/nodes/<node-name>.conf. -
Locate the section of the node configuration file that contains the existing object storage block device mappings.
In the example,
BLOCK_DEVICE_RANGEDB_00toBLOCK_DEVICE_RANGEDB_03are the existing object storage block device mappings.NODE_TYPE = VM_Storage_Node ADMIN_IP = 10.1.0.2 BLOCK_DEVICE_VAR_LOCAL = /dev/mapper/sgws-sn1-var-local BLOCK_DEVICE_RANGEDB_00 = /dev/mapper/sgws-sn1-rangedb-0 BLOCK_DEVICE_RANGEDB_01 = /dev/mapper/sgws-sn1-rangedb-1 BLOCK_DEVICE_RANGEDB_02 = /dev/mapper/sgws-sn1-rangedb-2 BLOCK_DEVICE_RANGEDB_03 = /dev/mapper/sgws-sn1-rangedb-3 GRID_NETWORK_TARGET = bond0.1001 ADMIN_NETWORK_TARGET = bond0.1002 CLIENT_NETWORK_TARGET = bond0.1003 GRID_NETWORK_IP = 10.1.0.3 GRID_NETWORK_MASK = 255.255.255.0 GRID_NETWORK_GATEWAY = 10.1.0.1
Add new object storage block device mappings corresponding to the block storage volumes you added for this Storage Node.
Make sure to start at the next
BLOCK_DEVICE_RANGEDB_nn. Don't leave a gap.-
Based on the example above, start at
BLOCK_DEVICE_RANGEDB_04. -
In the example below, four new block storage volumes have been added to the node:
BLOCK_DEVICE_RANGEDB_04toBLOCK_DEVICE_RANGEDB_07.
NODE_TYPE = VM_Storage_Node ADMIN_IP = 10.1.0.2 BLOCK_DEVICE_VAR_LOCAL = /dev/mapper/sgws-sn1-var-local BLOCK_DEVICE_RANGEDB_00 = /dev/mapper/sgws-sn1-rangedb-0 BLOCK_DEVICE_RANGEDB_01 = /dev/mapper/sgws-sn1-rangedb-1 BLOCK_DEVICE_RANGEDB_02 = /dev/mapper/sgws-sn1-rangedb-2 BLOCK_DEVICE_RANGEDB_03 = /dev/mapper/sgws-sn1-rangedb-3 BLOCK_DEVICE_RANGEDB_04 = /dev/mapper/sgws-sn1-rangedb-4 BLOCK_DEVICE_RANGEDB_05 = /dev/mapper/sgws-sn1-rangedb-5 BLOCK_DEVICE_RANGEDB_06 = /dev/mapper/sgws-sn1-rangedb-6 BLOCK_DEVICE_RANGEDB_07 = /dev/mapper/sgws-sn1-rangedb-7 GRID_NETWORK_TARGET = bond0.1001 ADMIN_NETWORK_TARGET = bond0.1002 CLIENT_NETWORK_TARGET = bond0.1003 GRID_NETWORK_IP = 10.1.0.3 GRID_NETWORK_MASK = 255.255.255.0 GRID_NETWORK_GATEWAY = 10.1.0.1
Run the following command to validate your changes to the node configuration file for the Storage Node:
sudo storagegrid node validate <node-name>Address any errors or warnings before proceeding to the next step.
If you observe an error similar to the following, it means that the node configuration file is attempting to map the block device used by
<node-name>for<PURPOSE>to the given<path-name>in the Linux file system, but there is not a valid block device special file (or softlink to a block device special file) at that location.Checking configuration file for node <node-name>… ERROR: BLOCK_DEVICE_<PURPOSE> = <path-name> <path-name> is not a valid block device
Verify that you entered the correct
<path-name>. -
Run the following command to restart the node with the new block device mappings in place:
sudo storagegrid node start <node-name> -
Log in to the Storage Node as admin using the password listed in the
Check that the services start correctly:
View a list of the status of all services on the server:
sudo storagegrid-statusThe status is updated automatically.
Wait until all services are Running or Verified.
Exit the status screen:
Ctrl+C
Configure the new storage for use by the Storage Node:
Configure the new storage volumes:
sudo add_rangedbs.rbThis script finds any new storage volumes and prompts you to format them.
Enter y to format the storage volumes.
If any of the volumes have previously been formatted, decide if you want to reformat them.
Enter y to reformat.
Enter n to skip reformatting.
The
setup_rangedbs.shscript runs automatically. -
Verify that the Storage Node is online:
Sign in to the Grid Manager using a supported web browser.
Select SUPPORT > Tools > Grid topology.
Select site > Storage Node > LDR > Storage.
Select the Configuration tab and then the Main tab.
If the Storage State - Desired drop-down list is set to Read-only or Offline, select Online.
Click Apply Changes.
To see the new object stores:
Select NODES > site > Storage Node > Storage.
View the details in the Object Stores table.
You can now use the expanded capacity of the Storage Nodes to save object data.
