Replace hardware components in optional 60-drive expansion shelf
You might need to replace an input/output module, a power supply, or a fan in the expansion shelf.
Before you begin
You have the E-Series hardware replacement procedure.
You have physically located the storage appliance where you are replacing expansion shelf hardware components in the data center.
About this task
To replace an input/output module (IOM) in a 60-drive expansion shelf, see the steps in the instructions for replacing a storage controller.
To replace a power supply or a fan in a 60-drive expansion shelf, access the E-Series procedures for maintaining 60-drive hardware.
| FRU | See E-Series instructions for |
Input/output module (IOM) |
Replacing an IOM |
Power canister |
Replace power canister (60-drive) |
Fan canister |
Replace fan canister (60-drive) |
