About the bycast.log
The file /var/local/log/bycast.log is the primary troubleshooting file for the StorageGRID software. There is a bycast.log file for every grid node. The file contains messages specific to that grid node.
The file /var/local/log/bycast-err.log is a subset of bycast.log. It contains messages of severity ERROR and CRITICAL.
Optionally, you can change the destination of audit logs and send audit information to an external syslog server. Local logs of audit records continue to be generated and stored when an external syslog server is configured. See Configure audit messages and log destinations.
File rotation for bycast.log
When the bycast.log file reaches 1 GB, the existing file is saved, and a new log file is started.
The saved file is renamed bycast.log.1, and the new file is named bycast.log. When the new bycast.log reaches 1 GB, bycast.log.1 is renamed and compressed to become bycast.log.2.gz, and bycast.log is renamed bycast.log.1.
The rotation limit for bycast.log is 21 files. When the 22nd version of the bycast.log file is created, the oldest file is deleted.
The rotation limit for bycast-err.log is seven files.
If a log file has been compressed, you must not uncompress it to the same location in which it was written. Uncompressing the file to the same location can interfere with the log rotation scripts. |
Messages in bycast.log
Messages in bycast.log are written by the ADE (Asynchronous Distributed Environment). ADE is the runtime environment used by each grid node's services.
Example ADE message:
May 15 14:07:11 um-sec-rg1-agn3 ADE: |12455685 0357819531 SVMR EVHR 2019-05-05T27T17:10:29.784677| ERROR 0906 SVMR: Health check on volume 3 has failed with reason 'TOUT'
ADE messages contain the following information:
| Message segment | Value in example |
Node ID  |
ADE process ID  |
Module name  |
Message identifier  |
UTC system time  |
Severity level  |
Internal tracking number  |
Message  |
Message severities in bycast.log
The messages in bycast.log are assigned severity levels.
For example:
NOTICE — An event that should be recorded has occurred. Most log messages are at this level.
WARNING — An unexpected condition has occurred.
ERROR — A major error has occurred that will impact operations.
CRITICAL — An abnormal condition has occurred that has stopped normal operations. You should address the underlying condition immediately. Critical messages are also displayed in the Grid Manager. Select SUPPORT > Tools > Grid topology. Then select Site > Node > SSM > Events.
Error codes in bycast.log
Most of the error messages in bycast.log contain error codes.
The following table lists common non-numerical codes in bycast.log. The exact meaning of a non-numerical code depends on the context in which it is reported.
| Error code | Meaning |
SUCS  |
No error  |
GERR  |
Unknown  |
CANC  |
Canceled  |
ABRT  |
Aborted  |
TOUT  |
Timeout  |
INVL  |
Invalid  |
NFND  |
Not found  |
VERS  |
Version  |
CONF  |
Configuration  |
FAIL  |
Failed  |
ICPL  |
Incomplete  |
DONE  |
Done  |
SUNV  |
Service unavailable  |
The following table lists the numerical error codes in bycast.log.
| Error number | Error code | Meaning |
001  |
EPERM  |
Operation not permitted  |
002  |
ENOENT  |
No such file or directory  |
003  |
ESRCH  |
No such process  |
004  |
EINTR  |
Interrupted system call  |
005  |
EIO  |
I/O error  |
006  |
ENXIO  |
No such device or address  |
007  |
E2BIG  |
Argument list too long  |
008  |
ENOEXEC  |
Exec format error  |
009  |
EBADF  |
Bad file number  |
010  |
ECHILD  |
No child processes  |
011  |
EAGAIN  |
Try again  |
012  |
ENOMEM  |
Out of memory  |
013  |
EACCES  |
Permission denied  |
014  |
EFAULT  |
Bad address  |
015  |
ENOTBLK  |
Block device required  |
016  |
EBUSY  |
Device or resource busy  |
017  |
EEXIST  |
File exists  |
018  |
EXDEV  |
Cross-device link  |
019  |
ENODEV  |
No such device  |
020  |
ENOTDIR  |
Not a directory  |
021  |
EISDIR  |
Is a directory  |
022  |
EINVAL  |
Invalid argument  |
023  |
ENFILE  |
File table overflow  |
024  |
EMFILE  |
Too many open files  |
025  |
ENOTTY  |
Not a typewriter  |
026  |
ETXTBSY  |
Text file busy  |
027  |
EFBIG  |
File too large  |
028  |
ENOSPC  |
No space left on device  |
029  |
ESPIPE  |
Illegal seek  |
030  |
EROFS  |
Read-only file system  |
031  |
EMLINK  |
Too many links  |
032  |
EPIPE  |
Broken pipe  |
033  |
EDOM  |
Math argument out of domain of func  |
034  |
ERANGE  |
Math result not representable  |
035  |
EDEADLK  |
Resource deadlock would occur  |
036  |
ENAMETOOLONG  |
File name too long  |
037  |
ENOLCK  |
No record locks available  |
038  |
ENOSYS  |
Function not implemented  |
039  |
ENOTEMPTY  |
Directory not empty  |
040  |
ELOOP  |
Too many symbolic links encountered  |
041  |
042  |
ENOMSG  |
No message of desired type  |
043  |
EIDRM  |
Identifier removed  |
044  |
ECHRNG  |
Channel number out of range  |
045  |
EL2NSYNC  |
Level 2 not synchronized  |
046  |
EL3HLT  |
Level 3 halted  |
047  |
EL3RST  |
Level 3 reset  |
048  |
ELNRNG  |
Link number out of range  |
049  |
EUNATCH  |
Protocol driver not attached  |
050  |
ENOCSI  |
No CSI structure available  |
051  |
EL2HLT  |
Level 2 halted  |
052  |
EBADE  |
Invalid exchange  |
053  |
EBADR  |
Invalid request descriptor  |
054  |
EXFULL  |
Exchange full  |
055  |
ENOANO  |
No anode  |
056  |
EBADRQC  |
Invalid request code  |
057  |
EBADSLT  |
Invalid slot  |
058  |
059  |
EBFONT  |
Bad font file format  |
060  |
ENOSTR  |
Device not a stream  |
061  |
ENODATA  |
No data available  |
062  |
ETIME  |
Timer expired  |
063  |
ENOSR  |
Out of streams resources  |
064  |
ENONET  |
Machine is not on the network  |
065  |
ENOPKG  |
Package not installed  |
066  |
EREMOTE  |
Object is remote  |
067  |
ENOLINK  |
Link has been severed  |
068  |
EADV  |
Advertise error  |
069  |
ESRMNT  |
Srmount error  |
070  |
ECOMM  |
Communication error on send  |
071  |
EPROTO  |
Protocol error  |
072  |
EMULTIHOP  |
Multihop attempted  |
073  |
EDOTDOT  |
RFS specific error  |
074  |
EBADMSG  |
Not a data message  |
075  |
EOVERFLOW  |
Value too large for defined data type  |
076  |
ENOTUNIQ  |
Name not unique on network  |
077  |
EBADFD  |
File descriptor in bad state  |
078  |
EREMCHG  |
Remote address changed  |
079  |
ELIBACC  |
Can't access a needed shared library  |
080  |
ELIBBAD  |
Accessing a corrupted shared library  |
081  |
ELIBSCN  |
082  |
ELIBMAX  |
Attempting to link in too many shared libraries  |
083  |
ELIBEXEC  |
Can't exec a shared library directly  |
084  |
EILSEQ  |
Illegal byte sequence  |
085  |
ERESTART  |
Interrupted system call should be restarted  |
086  |
ESTRPIPE  |
Streams pipe error  |
087  |
EUSERS  |
Too many users  |
088  |
ENOTSOCK  |
Socket operation on non-socket  |
089  |
EDESTADDRREQ  |
Destination address required  |
090  |
EMSGSIZE  |
Message too long  |
091  |
EPROTOTYPE  |
Protocol wrong type for socket  |
092  |
ENOPROTOOPT  |
Protocol not available  |
093  |
EPROTONOSUPPORT  |
Protocol not supported  |
094  |
ESOCKTNOSUPPORT  |
Socket type not supported  |
095  |
EOPNOTSUPP  |
Operation not supported on transport endpoint  |
096  |
EPFNOSUPPORT  |
Protocol family not supported  |
097  |
EAFNOSUPPORT  |
Address family not supported by protocol  |
098  |
EADDRINUSE  |
Address already in use  |
099  |
EADDRNOTAVAIL  |
Can't assign requested address  |
100  |
ENETDOWN  |
Network is down  |
101  |
ENETUNREACH  |
Network is unreachable  |
102  |
ENETRESET  |
Network dropped connection because of reset  |
103  |
ECONNABORTED  |
Software caused connection to terminate  |
104  |
ECONNRESET  |
Connection reset by peer  |
105  |
ENOBUFS  |
No buffer space available  |
106  |
EISCONN  |
Transport endpoint is already connected  |
107  |
ENOTCONN  |
Transport endpoint is not connected  |
108  |
ESHUTDOWN  |
Can't send after transport endpoint shutdown  |
109  |
ETOOMANYREFS  |
Too many references: can't splice  |
110  |
ETIMEDOUT  |
Connection timed out  |
111  |
ECONNREFUSED  |
Connection refused  |
112  |
EHOSTDOWN  |
Host is down  |
113  |
EHOSTUNREACH  |
No route to host  |
114  |
EALREADY  |
Operation already in progress  |
115  |
EINPROGRESS  |
Operation now in progress  |
116  |
117  |
EUCLEAN  |
Structure needs cleaning  |
118  |
ENOTNAM  |
Not a XENIX named type file  |
119  |
ENAVAIL  |
No XENIX semaphores available  |
120  |
EISNAM  |
Is a named type file  |
121  |
EREMOTEIO  |
Remote I/O error  |
122  |
EDQUOT  |
Quota exceeded  |
123  |
ENOMEDIUM  |
No medium found  |
124  |
EMEDIUMTYPE  |
Wrong medium type  |
125  |
ECANCELED  |
Operation Canceled  |
126  |
ENOKEY  |
Required key not available  |
127  |
EKEYEXPIRED  |
Key has expired  |
128  |
EKEYREVOKED  |
Key has been revoked  |
129  |
EKEYREJECTED  |
Key was rejected by service  |
130  |
EOWNERDEAD  |
For robust mutexes: Owner died  |
131  |
ENOTRECOVERABLE  |
For robust mutexes: State not recoverable  |
