About the bycast.log
The file /var/local/log/bycast.log is the primary troubleshooting file for the StorageGRID software. There is a bycast.log file for every grid node. The file contains messages specific to that grid node.
The file /var/local/log/bycast-err.log is a subset of bycast.log. It contains messages of severity ERROR and CRITICAL.
Optionally, you can change the destination of audit logs and send audit information to an external syslog server. Local logs of audit records continue to be generated and stored when an external syslog server is configured. See Configure audit messages and log destinations.
File rotation for bycast.log
When the bycast.log file reaches 1 GB, the existing file is saved, and a new log file is started.
The saved file is renamed bycast.log.1, and the new file is named bycast.log. When the new bycast.log reaches 1 GB, bycast.log.1 is renamed and compressed to become bycast.log.2.gz, and bycast.log is renamed bycast.log.1.
The rotation limit for bycast.log is 21 files. When the 22nd version of the bycast.log file is created, the oldest file is deleted.
The rotation limit for bycast-err.log is seven files.
Note If a log file has been compressed, you must not uncompress it to the same location in which it was written. Uncompressing the file to the same location can interfere with the log rotation scripts.
Related information
Collect log files and system data
Messages in bycast.log
Messages in bycast.log are written by the ADE (Asynchronous Distributed Environment). ADE is the runtime environment used by each grid node's services.
Example ADE message:
May 15 14:07:11 um-sec-rg1-agn3 ADE: |12455685    0357819531
SVMR EVHR 2019-05-05T27T17:10:29.784677| ERROR 0906 SVMR: Health
check on volume 3 has failed with reason 'TOUT'
ADE messages contain the following information:
Message segment Value in example
Node ID
12455685
ADE process ID
0357819531
Module name
SVMR
Message identifier
EVHR
UTC system time
2019-05-05T27T17:10:29.784677 (YYYY-MM-DDTHH:MM:SS.uuuuuu)
Severity level
ERROR
Internal tracking number
0906
Message
SVMR: Health check on volume 3 has failed with reason 'TOUT'
Message severities in bycast.log
The messages in bycast.log are assigned severity levels.
For example:
  • NOTICE — An event that should be recorded has occurred. Most log messages are at this level.
  • WARNING — An unexpected condition has occurred.
  • ERROR — A major error has occurred that will impact operations.
  • CRITICAL — An abnormal condition has occurred that has stopped normal operations. You should address the underlying condition immediately.
Error codes in bycast.log
Most of the error messages in bycast.log contain error codes.
The following table lists common non-numerical codes in bycast.log. The exact meaning of a non-numerical code depends on the context in which it is reported.
Error code Meaning
SUCS
No error
GERR
Unknown
CANC
Canceled
ABRT
Aborted
TOUT
Timeout
INVL
Invalid
NFND
Not found
VERS
Version
CONF
Configuration
FAIL
Failed
ICPL
Incomplete
DONE
Done
SUNV
Service unavailable
The following table lists the numerical error codes in bycast.log.
Error number Error code Meaning
001
EPERM
Operation not permitted
002
ENOENT
No such file or directory
003
ESRCH
No such process
004
EINTR
Interrupted system call
005
EIO
I/O error
006
ENXIO
No such device or address
007
E2BIG
Argument list too long
008
ENOEXEC
Exec format error
009
EBADF
Bad file number
010
ECHILD
No child processes
011
EAGAIN
Try again
012
ENOMEM
Out of memory
013
EACCES
Permission denied
014
EFAULT
Bad address
015
ENOTBLK
Block device required
016
EBUSY
Device or resource busy
017
EEXIST
File exists
018
EXDEV
Cross-device link
019
ENODEV
No such device
020
ENOTDIR
Not a directory
021
EISDIR
Is a directory
022
EINVAL
Invalid argument
023
ENFILE
File table overflow
024
EMFILE
Too many open files
025
ENOTTY
Not a typewriter
026
ETXTBSY
Text file busy
027
EFBIG
File too large
028
ENOSPC
No space left on device
029
ESPIPE
Illegal seek
030
EROFS
Read-only file system
031
EMLINK
Too many links
032
EPIPE
Broken pipe
033
EDOM
Math argument out of domain of func
034
ERANGE
Math result not representable
035
EDEADLK
Resource deadlock would occur
036
ENAMETOOLONG
File name too long
037
ENOLCK
No record locks available
038
ENOSYS
Function not implemented
039
ENOTEMPTY
Directory not empty
040
ELOOP
Too many symbolic links encountered
041
042
ENOMSG
No message of desired type
043
EIDRM
Identifier removed
044
ECHRNG
Channel number out of range
045
EL2NSYNC
Level 2 not synchronized
046
EL3HLT
Level 3 halted
047
EL3RST
Level 3 reset
048
ELNRNG
Link number out of range
049
EUNATCH
Protocol driver not attached
050
ENOCSI
No CSI structure available
051
EL2HLT
Level 2 halted
052
EBADE
Invalid exchange
053
EBADR
Invalid request descriptor
054
EXFULL
Exchange full
055
ENOANO
No anode
056
EBADRQC
Invalid request code
057
EBADSLT
Invalid slot
058
059
EBFONT
Bad font file format
060
ENOSTR
Device not a stream
061
ENODATA
No data available
062
ETIME
Timer expired
063
ENOSR
Out of streams resources
064
ENONET
Machine is not on the network
065
ENOPKG
Package not installed
066
EREMOTE
Object is remote
067
ENOLINK
Link has been severed
068
EADV
Advertise error
069
ESRMNT
Srmount error
070
ECOMM
Communication error on send
071
EPROTO
Protocol error
072
EMULTIHOP
Multihop attempted
073
EDOTDOT
RFS specific error
074
EBADMSG
Not a data message
075
EOVERFLOW
Value too large for defined data type
076
ENOTUNIQ
Name not unique on network
077
EBADFD
File descriptor in bad state
078
EREMCHG
Remote address changed
079
ELIBACC
Can't access a needed shared library
080
ELIBBAD
Accessing a corrupted shared library
081
ELIBSCN
082
ELIBMAX
Attempting to link in too many shared libraries
083
ELIBEXEC
Can't exec a shared library directly
084
EILSEQ
Illegal byte sequence
085
ERESTART
Interrupted system call should be restarted
086
ESTRPIPE
Streams pipe error
087
EUSERS
Too many users
088
ENOTSOCK
Socket operation on non-socket
089
EDESTADDRREQ
Destination address required
090
EMSGSIZE
Message too long
091
EPROTOTYPE
Protocol wrong type for socket
092
ENOPROTOOPT
Protocol not available
093
EPROTONOSUPPORT
Protocol not supported
094
ESOCKTNOSUPPORT
Socket type not supported
095
EOPNOTSUPP
Operation not supported on transport endpoint
096
EPFNOSUPPORT
Protocol family not supported
097
EAFNOSUPPORT
Address family not supported by protocol
098
EADDRINUSE
Address already in use
099
EADDRNOTAVAIL
Can't assign requested address
100
ENETDOWN
Network is down
101
ENETUNREACH
Network is unreachable
102
ENETRESET
Network dropped connection because of reset
103
ECONNABORTED
Software caused connection to terminate
104
ECONNRESET
Connection reset by peer
105
ENOBUFS
No buffer space available
106
EISCONN
Transport endpoint is already connected
107
ENOTCONN
Transport endpoint is not connected
108
ESHUTDOWN
Can't send after transport endpoint shutdown
109
ETOOMANYREFS
Too many references: can't splice
110
ETIMEDOUT
Connection timed out
111
ECONNREFUSED
Connection refused
112
EHOSTDOWN
Host is down
113
EHOSTUNREACH
No route to host
114
EALREADY
Operation already in progress
115
EINPROGRESS
Operation now in progress
116
117
EUCLEAN
Structure needs cleaning
118
ENOTNAM
Not a XENIX named type file
119
ENAVAIL
No XENIX semaphores available
120
EISNAM
Is a named type file
121
EREMOTEIO
Remote I/O error
122
EDQUOT
Quota exceeded
123
ENOMEDIUM
No medium found
124
EMEDIUMTYPE
Wrong medium type
125
ECANCELED
Operation Canceled
126
ENOKEY
Required key not available
127
EKEYEXPIRED
Key has expired
128
EKEYREVOKED
Key has been revoked
129
EKEYREJECTED
Key was rejected by service
130
EOWNERDEAD
For robust mutexes: Owner died
131
ENOTRECOVERABLE
For robust mutexes: State not recoverable
