LLST: Location Lost
This message is generated whenever a location for an object copy (replicated or erasure coded) can't be found.
| Code | Field | Description |
CBIL |
CBID |
The affected CBID. |
ECPR |
Erasure Coding Profile |
For erasure-coded object data. The ID of the erasure coding profile used. |
LTYP |
Location Type |
CLDI (Online): For replicated object data CLEC (Online): For erasure-coded object data CLNL (Nearline): For archived replicated object data |
NOID |
Source Node ID |
The node ID on which the locations were lost. |
PCLD |
Path to replicated object |
The complete path to the disk location of the lost object data. Only returned when LTYP has a value of CLDI (that is, for replicated objects). Takes the form |
RSLT |
Result |
Always NONE. RSLT is a mandatory message field, but is not relevant for this message. NONE is used rather than SUCS so that this message is not filtered. |
TSRC |
Triggering Source |
USER: User triggered SYST: System triggered |
UUID |
Universally Unique ID |
The identifier of the affected object in the StorageGRID system. |
