LLST: Location Lost
This message is generated whenever a location for an object copy (replicated or erasure-coded) can't be found.
Code Field Description
CBIL
CBID
The affected CBID.
ECPR
Erasure-Coding Profile
For erasure-coded object data. The ID of the erasure-coding profile used.
LTYP
Location Type
CLDI (Online): For replicated object data
CLEC (Online): For erasure-coded object data
CLNL (Nearline): For archived replicated object data
NOID
Source Node ID
The node ID on which the locations were lost.
PCLD
Path to replicated object
The complete path to the disk location of the lost object data. Only returned when LTYP has a value of CLDI (that is, for replicated objects).
Takes the form /var/local/rangedb/2/p/13/13/00oJs6X%{h{U)SeUFxE@
RSLT
Result
Always NONE. RSLT is a mandatory message field, but is not relevant for this message. NONE is used rather than SUCS so that this message is not filtered.
TSRC
Triggering Source
USER: User triggered
SYST: System triggered
UUID
Universally Unique ID
The identifier of the affected object in the StorageGRID system.
